primary fan problem?
i just got finished resealing my water pump. after i had everything back together....it keeps overheating because my primary fan doesn't want to kick on. the secondary fan comes on fine but for some reason the primary won't. i tried to switch by putting the secondary fan on the primary connector but that did nothing. it is obviously not the fan and i also changed the fan relay and that also fixed nothing. you guys have any other stuff that i could check as far as what could be causing this prob...?
thanks
dan
thanks
dan
from what I am reading.... you seemed to have already found the cause of the primary fan not turning on, if the secondary fan turns on but not the primary, than you switch the connectors and the primary still dose not work than the primary fan motor must be burnt out. you can try powering the fan manualy to. I would use somthing called a power probe to ground and power the fan but thats not a tool most people have around, so you can also use jumper wires to supply power and ground to the fan motor
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
