preloading with 7/16 studs...
Old Jan 29, 2005 | 09:54 AM
dhirocz's Avatar
...would be different that preloading 3/8 studs right? I originally set the preload on my promags to 1/4 turn, then I started going to 1/2 turn...but it just occured to me that many people use 3/8 studs and they have a different thread pitch. Any preload specs for us guys using 7/16 studs? I'm used to setting preload at 1/2 turn with stock lifters, 1/4 turn with high energy lifters and zero with comp R's, but that's assuming a 3/8 stud.
Old Jan 29, 2005 | 10:29 AM
quickSS's Avatar
Re: preloading with 7/16 studs...
I wrote that down somewhere after having the same question.
here. I found it.
3/8 stud has a fine thread, .020" per 1/2 turn
7/16" sud has a less fine thread, .030" per 1/2 turn.
Those are from my measurements with a ruler.
Does that jibe with other's measurements?
Karl Ellwein
Old Jan 29, 2005 | 11:29 AM
OldSStroker's Avatar
here. I found it.
Karl Ellwein
3/8 fine pitch threads are 3/8-24 or 24 threads per inch(TPI). Each thread is then 1/24 or .04167 per turn or .0208 per 1/2 turn.
On most calculators, enter 24, then 'divide' then 'equals' to get the reciprocal (.041666...). If your calculator has a "1/x" button use that. Divide the answer by 2 to get the 1/2 turn, or divide it by 6 to get how much one flat of the nut moves the rocker.
7/16 fine pitch is 7/16-20 or 20 TPI. You can do the math.
FWIW, a micrometer (inch, not metric) has a very accurate 40 TPI thread. That's how it gives you measurements: .0250 per turn.
"Understanding how to get the answer is easier than memorizing the answer."
Old Jan 29, 2005 | 03:54 PM
dhirocz's Avatar
so the threads on the 7/16 studs aren't as fine by roughly 17 percent in other words. Meaning I would have to turn the polylock 17 percent less with 7/16 studs...
so I'm guessing I should take it down roughly about 1/10 turn less? Does that sound accurate?
Old Jan 30, 2005 | 07:14 AM
arnie's Avatar
Why complicate things unnecessarily. As recommended, do the math. 20 tpi is .050" a revolution. What are you after? .010"? .020"? That will determine the degree of wrench rotation.
Old Jan 30, 2005 | 08:08 AM
quickSS's Avatar
Yes. pretty close I'd think.
Karl
Old Jan 30, 2005 | 10:13 AM
blown94's Avatar
LOL, this is a pretty funny thread. You guys realize you're talking about 1/10 of a turn? Id say setting them pretty much the same as the 3/8 stud preload is going to be close enough, unless you're building a top fuel dragster that is, which I know you're not.
Old Jan 30, 2005 | 12:13 PM
stereomandan's Avatar
I set my preload at 3/8 turn with 7/16 studs. So right between 1/4 and 1/2 turn. This is comparable to just a hair under 1/2 turn for 3/8" studs.
Dan
Old Jan 30, 2005 | 12:37 PM
dhirocz's Avatar
LOL, true, it is kinda funny...but I had a problem with guideplate wear not too long ago, and I couldn't figure out the problem, so it left me wondering if it had anything to do with the preloading of the rockers. Just wanna make sure it's done right.
HarleyZ28
Oct 5, 2015 06:23 AM
Aug 24, 2015 06:41 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Zero_to_69
Advanced Tech
Jul 23, 2003 06:37 AM
96speed
Apr 24, 2003 10:06 AM
