Powerslide at 75 into median
Old Oct 21, 2003 | 08:16 PM
  #16
2fbodies2NV's Avatar
Camber is basically the angle (top to bottom) that your tire sits on the road. For instance, + camber would have your tire leaning out more at the top than at the bottom, and - camber is just the opposite. It is also possible that you have a bent strut. I think sears sells inner tie rod tools. If not, your local auto parts store
should have one. Lisle is the most common brand name.
Old Oct 21, 2003 | 08:48 PM
  #17
jasons93z's Avatar
Originally posted by b-stevens
would coolant glow in ultraviolet light? because i believe the a/c dye is supposed to, and if coolant doesnt, that would make that problem more clear to which one is doing the leaking
coolant does not glow in uv light
Old Oct 21, 2003 | 09:08 PM
  #18
b-stevens's Avatar
thanks for all you're help but school has me pretty busy during the week plus work so i dont have much time to check these things out until the weekend
brentbrowning01
Dec 16, 2014 06:35 AM
Periculum
Sep 29, 2005 03:28 PM
PhantomTA
Feb 25, 2003 01:58 PM
