Powerslide at 75 into median
Old Oct 20, 2003 | 07:41 PM
b-stevens's Avatar
well, all i have to say is that obviously did some damage, cracked rims on passenger side, had some problems balancing the wheels afterwards and i think this is the culprit. How much should this cost to replace and my brother says its the tie rod? How much are the parts and how much would labor be? would it be hard to fix yourself?
http://www.geocities.com/elteewun/psstr.html
i suppose that link might be helpful
thanks in advance
EDIT: have a new set of stock rims, so that no longer is a problem
Old Oct 20, 2003 | 08:07 PM
Dave89IROC's Avatar
are you sure the tie rod in that pic is bent?
pull the clamps off that rubber/plastic dust boot and see how it looks
Old Oct 20, 2003 | 08:12 PM
b-stevens's Avatar
I havent taken the dust boot off to look at it but I will, the outside of my front passenger side wheel wears on the outside more than any of my other wheels, and its not from hard turning if that helps
Old Oct 20, 2003 | 08:28 PM
Dave89IROC's Avatar
check under that boot, but it does sound like it is bent, it is pretty easy to replace, you should see how once you move that boot, you will need an alignment after though
Old Oct 20, 2003 | 08:29 PM
b-stevens's Avatar
im not going to be able to fix it tonight but i want to look at it, should it be easy enough to just take off the boot and put it back on?
Old Oct 20, 2003 | 08:32 PM
joeSS97's Avatar
Looks like a coolant leak going on there too.
Old Oct 20, 2003 | 08:33 PM
b-stevens's Avatar
no i think thats from my a/c, i ran it today and theres a decent sized leak in the compressor, i had it dye tested and i think that is the color of the dye
Old Oct 20, 2003 | 08:40 PM
whitedakota's Avatar
im also going with..."it looks like a coolant leak!"...dont remeber a/c dye being prestone green!!! better take a closer look just to be on the safe side.
IMO,
steve
Old Oct 20, 2003 | 08:43 PM
Dave89IROC's Avatar
yes, the clamp at the rack end will probably be ruined by removing it, the clamp at the other end is a sping clamp and can just be slid down the tie rod, the clamp at the rack end can be replaced with a zip tie temporily if necessary, or a regular hose clamp permanently
then just slide the boot down the tie rod
Old Oct 20, 2003 | 08:50 PM
b-stevens's Avatar
IMO,
steve
thanks, ill have to take a look at it tomorrow, where should i look for leaks? radiator? what pipes/tubes should i be looking at?
i'll check out underneath the dust boot tomorrow as well
thanks and ill keep you guys updated with any more info and questions i have
Old Oct 20, 2003 | 09:06 PM
Dave89IROC's Avatar
IMO,
steve
if UV dye was ever added to the A/C, it will be that flouresent green color
Old Oct 20, 2003 | 09:59 PM
2fbodies2NV's Avatar
A new inner tie rod will cost about $30. But I doubt you bent it. Does the car pull to one side ? Your tire wear could also be because your camber is out. If there's room, you can take the inner tie rod off with an adjustable wrench. If not, you'll probably need an inner tie rod removal/installation tool. If you do change it, just remember to count the threads when you take off the outer tie rod so you can put it on the new inner tie rod in about the same place. Then take it to an alignment shop.
Old Oct 21, 2003 | 06:20 AM
b-stevens's Avatar
would coolant glow in ultraviolet light? because i believe the a/c dye is supposed to, and if coolant doesnt, that would make that problem more clear to which one is doing the leaking
Old Oct 21, 2003 | 06:22 AM
b-stevens's Avatar
I dont think my car pulls to one side but ill do some tests on that and check it out today, Ill post that up sometime after noon. does anybody have a picture of an inner tie rod tool? or a site that sells them so I know what I'm looking for... Aslo Im unfamiliar with what a camber is, any more info would be greatly appreciated. Thanks
Old Oct 21, 2003 | 06:36 PM
b-stevens's Avatar
Doesnt pull to one side but I wont have time to check underneath the dust boot today
