PowerMax 2050
Old Jul 29, 2003 | 04:37 PM
Da_Dark_Z28's Avatar
Question PowerMax 2050
I am wondering who is using Crane Cam Powermax 2050? Its spec’s are:
Degrees Duration @ .050 Int./Exh. 218/218
Degrees Advertised Duration Int./Exh. 280/280
Degree Lobe Separation 116
Open/Close @.050" Cam Lift Int./Exh. (2)40/50(12)
Lash Hot Int./Exh. .000/.000
Gross Lift Int./Exh. .498/.498
I am just wondering about it, because it has a CARB EO number for use in California. How is compared to the major one’s I see on the board, like Hotcam, CC305, or CC306? Also if it is a pretty good cam, what stall speed should I be looking at for the cam? Any advice is appreciated. Thanks…
Old Jul 30, 2003 | 09:31 AM
I guess no one is using this type of cam. Now the second question, since there is not that many people using it, is the cam any good?
Old Jul 30, 2003 | 09:35 AM
94formulabz's Avatar
Notice there is no int/exh split. This cam would be good on a head with more exhaust flow, our heads have less than the optimum ratio of intake to exhaust flow which is why cams with a split and more exh duration perform better. If your heads have exh port work done then it could be good.
Old Jul 30, 2003 | 09:40 AM
joeSS97's Avatar
The above post is right on.You might look at the CC 502 which is what I have.218/224
Old Jul 30, 2003 | 09:43 AM
Joe, you have any numbers? mine is about to go in within a couple weeks, can't wait.
Old Jul 30, 2003 | 09:46 AM
joeSS97's Avatar
No numbers yet.I have heads on the way Cant wait. The car pulls hard ,Havent taken it past 5500.You will like it I gaurantee.
Old Jul 30, 2003 | 04:21 PM
Hey, thanks for the help. I am planning to go with AFR 180cc heads, which also have a CARB EO number. Do you think they have enough exhaust work done to accommodate that crane cam? My goal is to make an occasional drag car, but mostly a car that can brush off those pesky AMG’s and M-series I am dealing with out here in Cali. Also, I heard a lot of good things with that cc502. If I can’t get the numbers right with the crane, I am definitely going with that cc502. Also it sound like I should forgo the torque converter and do a A4 to M6 conversion to really enjoy that cc502.
Brangeta
Events and Cruise Spots
Apr 10, 2009 02:54 PM
camaro79323
West South Central
Apr 2, 2009 07:33 PM
01pewterz
Feb 26, 2009 01:14 PM
NastyTA
Oct 26, 2005 07:17 PM
CatsTasteGood
Nov 6, 2003 07:33 PM
