Powerband of the Carbuerated LT1 manifold form GM
Old May 30, 2005 | 01:52 PM
BadBowS10's Avatar
What would you say the power band of the gm lt1 carbed manifold isun molested. Maybe 1500 to 6500 somewhere around there
greg
Old May 30, 2005 | 11:32 PM
BadBowS10's Avatar
Re: Powerband of the Carbuerated LT1 manifold form GM
Why is it that I never really get a reply to some of my posts. Just curious.
greg
Old May 30, 2005 | 11:44 PM
stik6shift93's Avatar
can't really help you, the reason is not to many people have used the carbed manifold. I've seen that it's worth about 10-15 hp more on a heads and cam motor though.
Old May 30, 2005 | 11:55 PM
faded93bird's Avatar
Being that the intake is a high rise, dual plane intake I would say 1500-6500
Keep up it stats
I have an extra long block in the garage and was thinking of putting a carb on it. Then into my friends drag preped Nova.
Faded
Old May 31, 2005 | 04:18 PM
67RSSS6SPD's Avatar
Most people don't like carbed LT1's loved mine until I spun a rod bearing.Loved it so much I,m building another. Here are some Dyno numbers with carb set up .Stock bottom end at flywheel with carb set up and stock f body cam 415ft@3750 366 hp@5250 / with hot cam + springs 424ft@3750 409hp@6000/ hot cam and 1.6 rockers 430ft @4250 421 hp@5750. all with stock "iron heads".
Old May 31, 2005 | 08:32 PM
rskrause's Avatar
Moderator
Keep up it stats
Faded
Sounds about right to me. 6,500 maybe is a little higher than I would expect though.
Rich
DirtyDaveW
Dec 1, 2016 05:37 PM
Noer
Feb 28, 2015 11:29 AM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
