Power window help
Power window help
My drivers side window moves back a forth when i put it down and up. What is broken in it. Also, the passenger side is real slow and someone had a solution how to fix it besides replacing the motor, i just forgot how. Thanks.
Re: Power window help
the window that moves back and forth, the regulator is probably off track or one of the pins that hold it together is broken. you should take off your door panel and have a look. as far as the other window, you have to replace the motor or just dont roll down the window.
