Power window help
Old Jul 24, 2004 | 05:45 AM
jasons93z's Avatar
Power window help
My drivers side window moves back a forth when i put it down and up. What is broken in it. Also, the passenger side is real slow and someone had a solution how to fix it besides replacing the motor, i just forgot how. Thanks.
Old Jul 24, 2004 | 06:04 AM
irishz28's Avatar
Re: Power window help
the window that moves back and forth, the regulator is probably off track or one of the pins that hold it together is broken. you should take off your door panel and have a look. as far as the other window, you have to replace the motor or just dont roll down the window.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
