Power steering pump won't tighten any ideas?
Old Oct 23, 2005 | 10:11 AM
ninety4formula's Avatar
Hey guys, after I pyut my motor back in my friend ended up stripping the lower bolt hole in the bracket for the pump to attach, now the other one just stripped out on me too. Is there a way of fixing this other than a helicoil or a new bracket? Either way I think its gonna be a lot of work. Some friends of mine have told me to take out the bolts and see if I can find some that are just a little bit longer to maybe catch some good threads, but that bracket is right on the block so I don't know if there are more threads even in the bracket itself. Any ideas?
Old Oct 23, 2005 | 11:18 AM
lt11997's Avatar
Re: Power steering pump won't tighten any ideas?
I would either retap the holes or drill them out and put helicoils in them. I like to do it the right way the first time so I don't have to fix it again.
Old Oct 23, 2005 | 11:52 AM
SnakeOiler's Avatar
The helicoil works well - I had to do this as well.
Now that I have the engine out of the car, it's getting a new bracket.
Old Oct 23, 2005 | 12:12 PM
Fastbird93's Avatar
I had to do this myself, only my PS Pump bolt holes shredded while the car was making a run on the dyno.
It's not that difficult to get the accessory bracket out. Just remove the alternator, PS Pump, Belt Tensioner, and just remove the three bolts holding the A/C Compressor to it. Then it's 4 9/16" bolts holding the accessory bracket to the block/head. Comes right out.
Do the helicoil. It works well. Very well.
Old Oct 23, 2005 | 12:21 PM
Dave89IROC's Avatar
agreed, helicoils will be stronger then it was stock as well
Old Oct 23, 2005 | 12:27 PM
Originally Posted by ninety4formula
... Is there a way of fixing this other than a helicoil or a new bracket? ...
Not really. I don't see why you couldn't do the helicoil with the bracket on the car.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
ro2207
Dec 4, 2014 06:18 PM
