power programer
Old Jun 23, 2007 | 01:02 PM
Danny McAdams's Avatar
power programer
94 LT1- Will the Hypertech programer take the program out of the module in car that I put in it, even tho the eng. is not in car module is still hooked up to harness. I wanted to use programmer on my 95 Formula but it must be clear of other output to another module. Any body know. D Mc
Old Jun 23, 2007 | 05:32 PM
The Engineer's Avatar
Once you download the performance program, the Hypertech programmer is "linked" to that vehicle's VIN#. It can not be used on another vehicle, unless the performance program is removed and the factory restored.
As long as you can turn the power on, I believe it should work. The programmers do the PCM programming without the engine.
WD
Heathen1
Jan 2, 2016 04:27 PM
TitoPR221
May 26, 2015 12:20 AM
XtremeLt1
Sep 13, 2002 08:50 PM
94z28jbw
Sep 8, 2002 03:22 PM
