Power loss and rough idle
Old Mar 8, 2004 | 05:01 PM
Chuckels's Avatar
Unhappy Power loss and rough idle
I just installed Jet Hot LTs and Y pipe with over the valve cover wires on my 1994 Z28. Heres the problem...When i first started driving it after the LT install it was fine but in the last few days when I'm driving under 3000 rpm's it will hesitate sometimes and start bucking...When I am rolling and push in the clutch the rpm's will surge between 1100 and 1400 and settle down.(this didnt happen before the LT's). When i first put the LT's on it idled fine but now it idles really rough and every few seconds it will spike up like a 100 rpm's. I have a ticking/hmmm noise in the speakers that was not there before the LT's. I have looked at the car in the dark and do not see any arching. The coil is only but about 4 months old. When I am crusing down on the highway it fells like it lacking lots of power. The car has 59k on it and the headers have emissions fittings. The only code that i am throwing is code 32 which is EGR failure. I know that i had an intermitnet EGR code before that would cause my ses light to go off. When i was doing the install I did drop a couple of plugs on the ground but all were gaped to spec. I have no idea where to start any suggestions would be a big help.
Old Mar 10, 2004 | 08:06 PM
Chuckels's Avatar
No sugestions anyone....I would really like some help
Old Mar 10, 2004 | 09:10 PM
slopokrodrigez's Avatar
EGR is the problem. Haven't looked up your code. If it's not answered when I get up tomorrow. I'll look it then.
When the EGR sticks open it causes bad idle and low rpm hesitation.
Old Mar 11, 2004 | 04:42 PM
Chuckels's Avatar
Would just disconnecting the EGR and then reconnecting it make the EGR stick open? How big of a deal is to get the EGR off?
Old Mar 11, 2004 | 08:17 PM
Z28Boss's Avatar
replacing or cleaning the egr isnt too bad, you can just feel around back there and get the 2 nuts off or you can get one of those little mirrors and look behind your intake with that to take it off.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
thenewkid
Nov 27, 2014 09:41 AM
