BAD gas mileage, running rich, HELP
Old Mar 11, 2004 | 07:58 PM
tagz's Avatar
Question BAD gas mileage, running rich, HELP
So i'm getting about 8.7 miles to the gallon!!! Thats absolutly horrible.
I was floorin it half the time, but that should still only bring me up to 10, maybe 11 if i'm lucky. Still not good. Any one have any idea what might be causing this?
I am running rich, about 10 percent. (ranges from 5-15 percent) The right side tends to run alittle more rich then the left. I scanned it with DATAMASTER, anyone who is good with reading this stuff, and could help me determine the problem... heres the file
Datamaster: http://angelfire.com/biz4/tagz/datamastergas.uni
Speadsheet: http://angelfire.com/biz4/tagz/gas.csv
Note: I changed the spark plugs about 200 miles ago. Was not running this rich before I changed them.
Old Mar 11, 2004 | 08:06 PM
z28Power's Avatar
When you changed your plugs, did you gap everything properly?
I know it's a stupid question, but it could help out.
You could also check to see if you have any spark arcing to the motor. I've heard of people having luck starting the motor when ti's pretty dark and checking for the arcing that way, it's pretty visible.
Haven't actually had an issue like this, but just giving you some info based on issues I've seen resolved in the past.
Maybe one or some of the plugs managed to back out a bit?
What do you think, your message was somewhat vague so I wanted to through a few things out there.
Old Mar 11, 2004 | 08:20 PM
dougy147's Avatar
from what i can tell from your data you either have a cylender or 2 not fireing on the right bank or a bad 02. the injector pulse readings are the same for both sides so you have the same amount of fuel going in on both, you just have to figure out why it's comming out of the right bank instead of burning. I would lean more toward the not fireing rather than a bad o2 because of the really bad gas mileage. thats what i got out of it anyway, good luck
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
