power loss at low rpms?
Old Aug 6, 2005 | 05:56 AM
andyuk's Avatar
hi guys
after driving for about 10mins my car struggles to pull away in 1st 2nd
till i get to say 3000rpm then everythings ok (full power)
theres no SES and i had my car scanned (no problems)
new:fuel filter,plugs,leads,previous owner fitted new opti (remanafactured)
and new coil and clutch
i thought it might be the egr so i deleted it all,but it still does it..
can anyone help!.... i want to fit my nitrous but i need to get this fixed first
thanks
Old Aug 7, 2005 | 06:53 AM
slopokrodrigez's Avatar
Re: power loss at low rpms?
Sticky injector? How fast does your fuel pressure drop when you shut if off? Do you have any starting issues?
How well does it idle? You say about 10 minutes, related to closed loop?
What is your vacuum at idle?
Have you looked for any tears or ends folded over on the elbow at the throttle body? Just got done showing a newby his was all torn to shreads.
Old Aug 8, 2005 | 04:39 AM
andyuk's Avatar
hi thanks for your help...
it happens when the air pump stops running after a few minutes is that when it goes into closed loop?
ive got a trickflow inlet elbow everythings fitted ok
it idles a little bit wavey up and down but you can hardly notice it and my car starts first time so i dont think its a fuel problem
i have got a intake oil leak where the egr is,would cause a vacuum leak?
Old Aug 9, 2005 | 04:29 PM
I've seen lots of engines "hunt" at idle due to low fuel supply. Couple that with the fact that during the warm up of your engine (open loop) it does not seem to suffer from the lack of power that it does when it leans out in closed loop. And that leads me to start looking in the fuel direction.
I'de check the fuel pressure and have your injectors flow matched. You can also try 2 tanks of this stuff. Available at a lot of parts stores and at dealers also. It's awesome. What could it hurt?
Old Aug 10, 2005 | 02:03 AM
andyuk's Avatar
i will try it and see what happens
Old Aug 10, 2005 | 02:16 AM
TobyZ28's Avatar
Sorry i think im missing something.. two tanks of what stuff?
Old Aug 10, 2005 | 03:15 AM
Black1995Z's Avatar
I was staring at his comment for a while thinking i misread.
Try getting your ICM tested.
Old Aug 10, 2005 | 05:16 AM
LOL that's funny. Kids, don't get in a hot tub and then try to type!
Here's the stuff to clean the top end of the engine. Try 2 tanks
http://www.autobahnpower.com/products.asp?recnumber=92
Available just about everywhere GOOD parts are sold.
Sorry I left it out of the last post.
Old Aug 10, 2005 | 12:43 PM
Netwrkengeer's Avatar
Check your wires and then read this thread.... http://www.camaross.com/forums/showthread.php?t=371298
REDNECKISBOSS
Mar 22, 2015 08:31 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
thenewkid
Nov 27, 2014 09:41 AM
