power estimates
Old 10-11-2006, 10:51 PM
inssane45's Avatar
power estimates
with mods in sig can anybody est. hp, 1/4 mi. mph. Thanks
it is a m6 by the way
inssane45 is offline
Old 10-12-2006, 06:47 AM
inssane45's Avatar
Re: power estimates
anybody
Old 10-12-2006, 12:28 PM
MeanGreen97Z's Avatar
Re: power estimates
I'd say you're making about 260rwhp and should be running low 13s with a good driver at around 104mph or so.
MeanGreen97Z is offline
Old 10-12-2006, 12:49 PM
CALL911's Avatar
Re: power estimates
Yeah, about 260-275 ish is the best you will see with just bolt ons on an LT1. Also probably with a good launch with DR's probably a low 13, 103-105 MPH range.
CALL911 is offline
Old 10-12-2006, 11:02 PM
inssane45's Avatar
Re: power estimates
what else could i do to get it closer to 300 rwhp without getting into motor
Old 10-12-2006, 11:25 PM
whtdvl's Avatar
Re: power estimates
long tubes, true duals and maybe getting the computer re-tuned would get you closer to the 300rwhp figure you want
whtdvl is offline
Old 10-13-2006, 06:17 AM
THEBEAST94TAGT's Avatar
Re: power estimates
Get some fully roller rocker arms like the comp cams pro-magnum, an electric water pump, Long tubes, dual cut outs (if you do this you wont need a true dual set up, and you will then be able to turn the noise on and off), and get tuned, tuned, tuned. Make sure the MAF is descreened and ported also. Upgrading your ignition prolly won't gain much hp, but its good to do.
THEBEAST94TAGT is offline
Old 10-13-2006, 07:31 PM
CALL911's Avatar
Re: power estimates
There's little else you can do except maybe the LT's, and a new tune. But even then I doubt you would breech the 300 RWHP line.
If you want to go cheep, and not touch the motor. I would say, a 50-75 shot of Nitrous.
If you think that may be risky, then I would agree with THEBEAST94AGT in saying get some new rocker arms at least. There's really only so much you can acheive with leaving your LT1 motor "stock".
CALL911 is offline
kirschman
05-01-2015 10:40 PM
cmsmith
04-11-2015 09:37 PM
warmeck
03-08-2015 08:01 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: power estimates
