power estimates
Re: power estimates
Originally Posted by CALL911
Yeah, about 260-275 ish is the best you will see with just bolt ons on an LT1. Also probably with a good launch with DR's probably a low 13, 103-105 MPH range.
Re: power estimates
Get some fully roller rocker arms like the comp cams pro-magnum, an electric water pump, Long tubes, dual cut outs (if you do this you wont need a true dual set up, and you will then be able to turn the noise on and off), and get tuned, tuned, tuned. Make sure the MAF is descreened and ported also. Upgrading your ignition prolly won't gain much hp, but its good to do.
Re: power estimates
There's little else you can do except maybe the LT's, and a new tune. But even then I doubt you would breech the 300 RWHP line.
If you want to go cheep, and not touch the motor. I would say, a 50-75 shot of Nitrous.
If you think that may be risky, then I would agree with THEBEAST94AGT in saying get some new rocker arms at least. There's really only so much you can acheive with leaving your LT1 motor "stock".
cmsmith
Apr 11, 2015 09:37 PM
