Powder coating headers
Old May 14, 2005 | 12:02 AM
blacklt1z's Avatar
One of my headers has a rust hole in the collecter. Im gonna take them of and weld them up. Id like to get them powder coated. I live outside Okc and dont know of a good place and what type of powder coating would be good.
Old May 14, 2005 | 12:13 AM
stephenspann27's Avatar
Re: Powder coating headers
I asked if powder coat would last on headers, a few day ago in this forum.. and someone said it would not last..
Old May 14, 2005 | 12:20 AM
96ta(nick)'s Avatar
Ask airborne coatings on 39th in okc, pretty sure it won't hold up but they might be able to ceramic cout them for you. Or you can send them to jet-hot.
Old May 14, 2005 | 12:57 AM
69vette's Avatar
i do all kinds of powdercoating and ceramic coating. you can put high temp powder coat that will last up to 1200 deg or you can do ceramic coating. I can do either for you if you need me to. just pm me if you want.
Old May 14, 2005 | 12:59 AM
breakmyfootoff's Avatar
How well does the high temp powder coating hold up, that would be pretty neat if it lasts awhile and doesn't discolor.
Old May 14, 2005 | 01:12 AM
blacklt1z's Avatar
Old May 14, 2005 | 02:40 AM
jdizzell's Avatar
Why not just ceramic coat it, you will get lower engine bay temps.
Old May 14, 2005 | 07:22 AM
A powder coat will be little more than cosmetic. A cera-metallic coating is applied to both sides of the tubing, and retains more heat, increasing exhaust scavenging and lowering under hood temperatures.
My EGT gauge shows temps above 1,200degF.
Old May 14, 2005 | 11:22 AM
BLinindoll's Avatar
Yeah, I was just about to say, exhaust temps usually get hotter then 1200 degrees.
Old May 14, 2005 | 11:23 AM
I wonder how much Ceramic coating actually helps? Doesn't one have any percentage figures on how much, ppl claim it reduced temperatures?
Old May 14, 2005 | 11:26 AM
BLinindoll's Avatar
Well, a better question would be how much HOTTER the temps were (in the exhaust anyway.) Hotter exhaust is better then cooler. EGT's would be nice to compare.
Old May 14, 2005 | 04:30 PM
Jet Hot has data on underhood temperature reduction, power gains from scavenging, and extended life due to reduction of stress cracking and corrosion. They publish it in ads, and I think its on their website. As usual, be skeptical of the manufacturer's claims, but it does give you a feel for the magnitude of the gains.
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 5, 2015 09:56 PM
R@mpage
Apr 20, 2015 10:02 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
ModdedNerd
Jan 29, 2015 07:23 PM
