Post pictures of OVC wires that do NOT go under the power steering pump
Old Feb 19, 2004 | 02:53 PM
slider's Avatar
Post Post pictures of OVC wires that do NOT go under the power steering pump
I routed mine under the pump, but I am replacing my crap arcing Taylors with MSD wires and I'd like to route them straight up from the opti. Anyone do this? can you post some pictures of how you routed them?
Old Feb 19, 2004 | 03:35 PM
rob2299usa's Avatar
I am at work right now but I will try and post a picture when I get home within the next hour...
Old Feb 19, 2004 | 10:51 PM
rob2299usa's Avatar
Exclamation
check your e-mail... let me know if you want any other angles
Old Feb 20, 2004 | 08:10 AM
slider's Avatar
Never got anything from you.
Old Feb 20, 2004 | 10:08 AM
Smokn '94 Z's Avatar
I seen pics of people who did this but their wires were all strap tied together coming up from the Opti.. That is not the best way to do it. Those wire should be seperated with looms of some sort. Behined the PWR Steering pump does that for you.. Why don't you want to do them behined the pump again? I too would like to see some other pics.
Old Feb 20, 2004 | 12:56 PM
Zepher's Avatar
email me some pics as well.
I have the Taylor setup, but haven't put them on yet.
zepher@transamws6.com
Old Feb 20, 2004 | 12:59 PM
DR.ZED's Avatar
Apparently if you remove the tensioner there is an area that allows this. I've never done it this way, but a buddy of mine (who posts here) did this.
Old Feb 20, 2004 | 01:04 PM
SVT Killer LV's Avatar
Re: Post pictures of OVC wires that do NOT go under the power steering pump
maybe if i replace my "crap" taylors that have been fine for over 2 years i might go faster
Old Feb 20, 2004 | 01:12 PM
LilJayV10's Avatar
Same here, I was not impressed with the taylor wires at all. on my buddy's 95 Z we replaced them with the MSD, those are alot better IMO. We ran them behing the pump and A/C, then put convoluted(SP?) plastic tubing, like the kind they use for wireing harnesses to keep it from rubbing against the block.
JAson
Old Feb 20, 2004 | 04:16 PM
slider's Avatar
Someone has got to have pictures!
Old Feb 21, 2004 | 05:25 PM
slider's Avatar
zzz
Old Feb 22, 2004 | 09:32 PM
slider's Avatar
zzz
Old Feb 23, 2004 | 07:37 AM
Ken95Z28's Avatar
Wires Not Behind the Pump
Old Feb 23, 2004 | 08:00 AM
93ZM6Tally's Avatar
That's how I did mine. Only caution is to be sure that the wires are well clear of the belt near the tensioner. I use a tie wrap that goes around the accessories mount, a little bit of a PITA to get it around it but once it's there you won't have any worries about the belt cutting the wires.
FWIW I too had problems with Taylor's arcing. I went with the MSD's and I believe that their wires are of a better quality. I like their crimping tool better and the little plastic numbering tabs that come with the wires is a nice touch.
Good luck.
HectorM52
Jul 30, 2017 11:46 AM
GigaMp3z
Feb 20, 2003 02:57 PM
JasonD
Jul 15, 2002 02:17 PM
