Possibly bad opti?
Old Oct 7, 2003 | 07:43 PM
Fast96WS6's Avatar
Possibly bad opti?
Car ran great sat night, then sun morning I couldnt get it started at all for some reason. Finally after swapping in my old obdII pcm, it started after 20 min of trying. Swaped in new pcm and drove fine. I thought this was odd
Car started great on mon morning with no probems. This morning had the same starting probem and it eventually started with about 30 min of cranking and recharging of battery. I was totally baffled until later today, I floored the car at low rpm's in 4th and it started mis firing. Other than that, the car drives great.
Im figuring the opti is about to die. Brand new coil, perfect fuel pressure, and all wires are secure. The symptoms seem like an opti, and I have 115K on the original. Am I correct or what else could it be?
If it is, i need to get a new Opti and install it by sat so i can go to SLP day. What great timing
Old Oct 7, 2003 | 11:03 PM
Fast96WS6's Avatar
Anyone TTT.
I searched everything on about the Opti, but I just want to know if I'm missing anything else it could be
Old Oct 7, 2003 | 11:06 PM
NewbieWar's Avatar
yea i think my opti is starting to go, its got a stumble in low rpm's but it'll probably be a while before it accually goes...
Old Oct 8, 2003 | 12:01 AM
TMD95Z28's Avatar
Re: Possibly bad opti?
did u mean that u had to recharged ur battery while cranking???
if its the opti problem, u dont have to worry, it only took me and my friend 3 hours to change an opti. Oh we didn't took off the waterpump, we'd only took off the pulley that was right in front of the optispark.. i guess me and my friend were lucky that day..
Old Oct 8, 2003 | 01:17 AM
DarkRider's Avatar
I think I am having the same problems just without a starting problem. My Z coughs at high RPM's but drives normal in lower RPM's and I have checked all ignition and fuel componenets and connections. I am thinking about going with the dynotech opti but I am not sure -have you heard anything about that particular opti system? My opti at the moment is the non vented so I am going to change it to the vented style hoping to restore performance.
Old Oct 8, 2003 | 09:24 AM
Fast96WS6's Avatar
Re: Re: Possibly bad opti?
No, I had tried to start it so many times that I killed the battery, so I had to recharge it to try again.
Old Oct 9, 2003 | 02:39 PM
TMD95Z28's Avatar
oh i thought ur battery just went dead over a night.. that means battery is leaking out..
my bad
thanks for clearing that out man
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Jan 5, 2015 07:14 PM
GigaMp3z
Feb 20, 2003 02:57 PM
