is it possible to use two knock sensors?
Old Sep 24, 2003 | 02:00 AM
93formula's Avatar
i just picked up a block out of a caprice, it has two knock sensors. im building it up do drop into my car, just wondering if theres a way to retain both knock sensors. i will be running a accel dfi, and the stock pcm will be retained to run the dash etc. i will be running a blower so i thought it would be neat if i could use both knock sensors.
Old Sep 24, 2003 | 02:04 AM
madwolf's Avatar
Just remove the other one and put a bolt in its place or leave it disconnected. It's not worth the hassle, especially considering how many radical setups are out there running just one.
Old Sep 24, 2003 | 02:05 AM
93formula's Avatar
woah that was fast! thanks.
Old Sep 24, 2003 | 08:31 AM
I'm sure that is a tapered pipe threaded hole, so use the proper pipe plug and not a bolt. You don't want it to leak.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
