Possible rocker arm ticking?
Old Apr 30, 2012 | 09:31 PM
SSinister11x's Avatar
I was cruisin around a corner today and missed a gear goin up the hill and shot the RPMs up to like 6 grand and now I have a pretty annoying ticking under the hood. I tightened my header bolts just a couple weeks ago but not sure if I did it tight enough? How hard is it to determine a rocker arm problem? What are the things I can do to fix em or upgrade them. I'd like to keep big buck mods out of the engine for now just because I know I need a new clutch and rebuild my M6 pretty soon.
Old May 1, 2012 | 01:45 AM
mrmint69's Avatar
Re: Possible rocker arm ticking?
You can take the valve covers off and see if anything is going on in there. How bad is the ticking? Maybe you damaged something.
Old May 1, 2012 | 02:39 AM
I just started er again and it seems to be coming from under the car. I could totally be wrong but maybe I'll take it to my exhaust guy and make sure it's not the long tubes or y pipe. If it's not can I take the valve covers off and let it run without making a mess?
Old May 1, 2012 | 08:41 AM
mrmint69's Avatar
I just use rags and it will catch most of the oil. You can wipe the rest after your done. Hope the noise isn't coming from the bottom of the engine. Is your oil pressure normal?
Old May 1, 2012 | 09:47 AM
sandman2100's Avatar
Rags and a cut sheet of cardboard or plastic. Anything to keep it from splattering my headers.
Old May 2, 2012 | 02:34 PM
Yeah Oil pressure is perfect. I'm now convinced it's a rocker noise on the driver side.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
