Is it possible for a rear main seal to leak on a fresh motor?
Old Jul 20, 2008 | 09:31 AM
  #16
irishz28's Avatar
what kind of seal did you use? when i did my 383 i used a fel-pro rear main seal and about 300 miles on the engine it was leaking. i put a new GM seal in and i have not seen a drop yet.
Old Jul 20, 2008 | 09:44 AM
  #17
Rising Phoenix's Avatar
Fel-Pro
Old Jul 20, 2008 | 05:22 PM
  #18
SS RRR's Avatar
The pics of the bellhousing mean nothing. Have you not taken the dust cover off the bellhousing yet? Other than taking pics, have you felt around behind the intake?
Old Jul 20, 2008 | 09:39 PM
  #19
I took these pics before I made this thread, the car is still at the exhaust shop so no, I haven't had a chance to pull off the cover.
I have felt behind the intake, it's dry, or at least I'm 99.9% sure it is.
Old Jul 20, 2008 | 10:44 PM
  #20
RACEON's Avatar
One thing on the Fel Pro one piece oil pan gasket is you do need to put RTV in the four corners of the gasket, above and below. Basically where your main caps meet the block, put rtv on, then install the gasket then put more on those spots on the gasket side meeting the pan.
It may not be what Fel Pro says, but mine never leaked after I did this in car when it did leak because I didnt put RTV (right stuff) in the corners.
The one piece seal can leak if damaged during install.
Old Jul 20, 2008 | 10:57 PM
  #21
Chevyguy358's Avatar
I have the exact same problem on my new 383...its been 1,000 miles and i'm still looking
Old Aug 8, 2008 | 12:04 AM
  #22
RACEON's Avatar
Any updates
HectorM52
Jul 30, 2017 11:46 AM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
