Is it possible to put LED bulbs in the tail lights?
From: Wasaga Beach, ON (formerly Ft. Lauderdale,FL)
I have a 1995 Z28. Is it possible to put LED replacement bulbs in our tail lights and rear sidemarkers? I am interested in BRIGHT bulbs. I am mainly interested in the brake/signal bulbs and reverse bulbs as well as the bulbs for the rear side markers.
As for the front I think I heard somewhere that it can't be done becasue the LED bulb won't flash. Is that true?
Mike
Mike
You can do anything as long as you got some time... the right adapters, and a good source at radioshack... You might have to modify your rear tale lamp housing a bit. Wonder what it would look like when you stomp the brakes though...???
