Is it possible for a header gasket leak to cause knock retard?
Old Sep 8, 2004 | 05:51 PM
big dave's Avatar
Like the topic states. I was having knock retard until I found that my rockers were set up a little too much on the loose side. Once readjusted, my KR went away. The next day the scanmaster was showing KR again. The rockers are still as quiet as when I had readjusted them but I did notice that I have a black spot right above my #2 and 4 primary tubes. Is it possible for me to be getting knock retard from a header gasket leak?
Old Sep 8, 2004 | 06:33 PM
chrism400's Avatar
Re: Is it possible for a header gasket leak to cause knock retard?
Absolutely! Many guys have trouble after installing headers. Get an Lt4 knock moddule and you shouldn't have any more problems. By the way, a leaky exhaust manifold can mess up an exhaust valve- I would get that fixed pretty soon.
Old Sep 8, 2004 | 07:46 PM
big dave's Avatar
Thanks alot for the reply, I was beginning to think no one else has had this problem. Even though I can't hear a leak I can definitely see the burn mark right above the gasket. I know it wasn't there before because these heads were just put back on the car. I do have an lt4 km already.
Old Sep 8, 2004 | 08:23 PM
chrism400's Avatar
Actually what I meant to say was some guys have trouble. Most don't but it can happen.
Old Sep 8, 2004 | 08:48 PM
big dave's Avatar
thanks again
Old Sep 8, 2004 | 09:25 PM
BlackbirdWS6's Avatar
dont mean to hijack the thread, but I had a leak on my passenger side header from a couple loose bolts of course. I had a ticking sound when it was leaking. Anyway, I retorqued the bolts and the sound is totally gone and everything seems nice and buttoned up. Some people told me the gasket is trashed and needs to be replaced since it leaked on it and would trash the gasket. Is this fact or an occasional thing? thanks
Old Sep 9, 2004 | 09:10 AM
TigerWoodsJr's Avatar
depends how bad the leak and how long it leaked. I tightened mine up a couple times and when I finally took the gaskets out to put the new heads on you could see a little damage to the gasket, but it wasn't anything serious.
Old Sep 9, 2004 | 03:08 PM
LittleRedZ's Avatar
i thought you sold the car? Glad to hear you still got it.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
maybe2fast
Mar 16, 2015 11:59 AM
thenewkid
Nov 27, 2014 09:41 AM
