Position of MAF censor?
*sensor, sorry
Weird question, which direction should the bar code or sticker with the serial number be facing on the MAF censor? I had mine turned awhile back a certain way and a guy at a local speed shop said I needed to turn it back or it would cause me to run rich. I turned it back, and somehow in the process of cleaning my airfilter/goofing off, I think it got turned wrong. Dumb question maybe, but I'll feel smarter for asking,
how does it need to be "turned?" Thanks
im not sure if putting a MAF in backwards would really make much difference how the sensor reads incoming air but if the arrows dont make sense then just remember the side with the terminal needs to point to your right, facing the front of your car. i forgot about the most obvious factor.. the screen be on the same side as the air filter
Mine (at least while I was still using it) says "this side toward air filter". The support rods in the center of the sensor are not symettrical - the "rounded" side of the supports goes toward the air filter, to provide smooth flow for the air around the supports. If you put it in backward, you will be flowing the air into the back side of the support rods, which is an open "U" shape, and will cause turbulance.... small, but of siginifcance.
No, no. I have the airflow going the right way. I mean do I need to rotate the sensor from front to back any? Kinda hard to explain. Image turning a lock with a key. You turn the **** over. Do I need to have the sensor turned any certain direction up or down?
68camaroboltz
Oct 5, 2015 11:56 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
