which posi unit to buy?
Old Mar 11, 2004 | 02:14 PM
J96Z's Avatar
I am going to be upgrading the rear end in my car since the seal is leaking and cant afford a 12 bolt at the time nor do I really need one. Which posi unit works the best? Eaton, Auburn or Torsen? What comes stock in a 96 Z28?
Old Mar 12, 2004 | 06:30 AM
IDOXLR8's Avatar
I am assuming you are referring to your pinion seal leaking. Is your stock posi bad? If not there is no reason to change out to another one. If you have your heart set on another posi than I would recommend going with an Aurburn (I think they are rebuildable).
Fatdog2
Apr 27, 2015 10:32 PM
blac94Z
29
Mar 25, 2015 04:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
