Porting ? Where to go to get material added?
Old Jun 21, 2003 | 01:58 PM
Kuma's Avatar
Hi,
Working on my LT4 heads I think I overdid the floors of the intake ports, dipped a little below the gasket line. Since I'm a perfectionist this is intolerable, so where can I go to get material added? Could a regular welding/fabrication shop do it? How much will it cost?
Thanks for the help, I'm kicking myself!!
Remember, kids, don't drink and grind!
Old Jun 21, 2003 | 03:02 PM
Mindgame's Avatar
Re: Porting ? Where to go to get material added?
Originally posted by Kuma
Hi,
Best thing.... find a shop that has experience in welding aluminum cylinder heads. To do it right is to remove all the stuff that aint a native part of the head (seats, guides, etc) and then weld the head. Then it needs to be normalized, then the machine work needs to be performed (been through this process a few times). This is the only safe way to have a head welded, otherwise you end up with seats that like to move around, valves that are at different heights, ooh lala.
If it's just minor welding and you just have to have it done, then make sure the shop has an oven to preheat the head. With a prheat, you can weld a head without warpage but I'd still check everything when getting it back.
If this is just a minor mismatch at the gasket then I'd say leave it as it is. Especially being the port floor..... that section doesn't really matter as much, hence guys usually leave the floor alone other than to remove the flash and reshape the short turn.
-Mindgame
Old Jun 21, 2003 | 03:31 PM
Ai's Avatar
Ai
I mentioned in the other thread.. at this point, that probably isnt the worst problem with the port, so unless it's really bad, i'd leave it alone.
Old Jun 21, 2003 | 04:02 PM
Kuma's Avatar
I've read that a little bit of a "step" up is actually good for reducing backflow to the intake. This in mind, should I match the intake to the head or leave them a little smaller?
The ceilings match up pretty well to the gasket, actually the other 3 sides look pretty good, I think it is my **** perfectionist coming out.
SkarodoM, so what IS the worst problem with the port you think?
Lloyd Elliot suggested that the main area to focus on with these heads is the valve throat area, which I haven't touched yet since my cheapo ebay electric die grinder *broke*.
Old Jun 22, 2003 | 08:51 PM
arnie's Avatar
Hi,
On the intake side, I'd be surprised if you couldn't get away with epoxy in lieu of welding.
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 21, 2015 10:21 AM
Aug 7, 2015 01:26 PM
bunker
Aug 1, 2015 09:47 PM
13qtr
Jul 19, 2015 05:30 PM
