Porting Kits
Old Aug 4, 2005 | 07:08 AM
93 4mula's Avatar
Porting Kits
Can sommeone show me which porting kit I need that has everything in it that I need to do a porting/polishing job on my heads. Im still learning about all this so Im not sure which kit has everything I need so I can start practicing. I want to work the bowls, ports etc
http://store.summitracing.com/defaul...=egnsearch.asp
Old Aug 4, 2005 | 10:02 AM
Slayn's Avatar
Re: Porting Kits
http://www.jegs.com/cgi-bin/ncommerc...40&prmenbr=361
Old Aug 4, 2005 | 10:12 AM
93 4mula's Avatar
Re: Porting Kits
So I can port and polish with everything that kit has? Wont have to buy anything extra?
Old Aug 4, 2005 | 10:42 AM
Slayn's Avatar
Re: Porting Kits
It's all of the bits your going to need to do a home port job
Old Aug 4, 2005 | 11:01 AM
93 4mula's Avatar
Re: Porting Kits
Can I port and polish with that kit?
Old Aug 5, 2005 | 02:29 AM
93 4mula's Avatar
Re: Porting Kits
any help??
Old Aug 5, 2005 | 07:33 PM
IDAREU's Avatar
Re: Porting Kits
I don't think any of those kits will work by themselves. It also depends on how much material you plan on removing, or if you are just going to clean up the casting. You'll need a really good rotary tool, preferably an extended reach air die-grinder, or at least a high powered dremel. As for the bits I would get a wide variety kit of abrasives, like the 1st one listed, as well as the 6 inch non-ferrous deburr carbide shanks, and if you could find a set of shorter carbide shanks to do the edge of the ports that would be good too. Those longer bits allow you to get in further but arent can bit a pain to keep steady on the edges. Oh and the most important thing, SAFEY GLASSES. Ya I thought I was gonna slip by here and there and not wear mine when I was being lazy. Those shavings fly eveywhere. If you can I would highly recommend finding a junker or cheap aluminum intake to just get some practice on.
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
Drtryder
Apr 22, 2015 04:17 PM
dfarr67
Apr 10, 2015 07:44 PM
bandit383lt4
Dec 21, 2014 09:12 PM
