Porting Heads
Old Jul 20, 2005 | 01:47 AM
93 4mula's Avatar
Porting Heads
Well Im fixing to start practicing on porting heads and I have the grinder I was curious if anyone knows where I can get all the bits what else I need to use to do the job. Also if anyone has any good pics of fully worked heads so I can have something to look at.. Also any tips would be greatly appreciated
Old Jul 20, 2005 | 06:02 AM
rskrause's Avatar
Moderator
Re: Porting Heads
Get David Vizzard's book on porting heads. Invaluable.
Rich
Old Aug 3, 2005 | 07:29 AM
93 4mula's Avatar
Re: Porting Heads
where can you get the bits from?
Old Aug 3, 2005 | 07:58 AM
Netwrkengeer's Avatar
Re: Porting Heads
www.summitracing.com
Search for porting kits
Old Aug 3, 2005 | 09:47 AM
93 4mula's Avatar
Re: Porting Heads
Is this all I need to do it correctly? Or do I need some kind of special bit?
http://store.summitracing.com/defaul...=egnsearch.asp
Old Aug 4, 2005 | 11:29 PM
arnie's Avatar
Re: Porting Heads
Mondello is a good source.
Old Aug 5, 2005 | 03:11 PM
limige's Avatar
Re: Porting Heads
Rich
i second that, i started before i read this book and really wish i would've read it first!
as for tools try www.jlindustrial.com
you'll need a 6" and 2" long carbide burr, round end
6"/4"/2" cartridge roll mandrel (known as tootsie rolls)
a box of 80 grit rolls
and i suggest a fine grit polishing stone such as a 240 or so and some emory cloth.
a nice 4" 120 grit flopper wheel works wonders for the chambers.
lookup that book, it's $15 for some invaluable knowledge.
mike
Old Aug 6, 2005 | 05:36 AM
93 4mula's Avatar
Re: Porting Heads
Where do you get this book from? I found some of his books but nothing on porting and polishing. Found one on cylinder heads but it was 60 bucks
Old Aug 6, 2005 | 05:44 AM
Jameslt1TA's Avatar
Re: Porting Heads
Remember you need non ferrous bits for aluminum heads...but when you buy them they should say that they are for aluminum.
Old Aug 6, 2005 | 06:03 AM
93 4mula's Avatar
Re: Porting Heads
gotcha...anyone know where I can get that book?
Old Aug 6, 2005 | 06:43 AM
sssalah's Avatar
Re: Porting Heads
http://www.amazon.com/exec/obidos/tg...glance&s=books
He has other books that are very usefull like his camshaft book.
Old Aug 6, 2005 | 06:52 AM
93 4mula's Avatar
Re: Porting Heads
Thanks I appreciate it.
Old Aug 6, 2005 | 07:41 AM
rskrause's Avatar
Moderator
Re: Porting Heads
He has two books on the subject, both available on Amazon.com. One is $14 and the other is $20. Do a search in books on "Vizard". They would be worth it if they were $100 though!
Rich
Old Aug 6, 2005 | 08:21 AM
93 4mula's Avatar
Re: Porting Heads
which one is better?
Old Aug 6, 2005 | 10:32 AM
FastZinTennessee's Avatar
Re: Porting Heads
Research first and TAKE YOUR TIME! The right tools for porting are worth it to buy! You will want to get that set of 3 6" non ferrous deburring bits(SUM-900630), you'll also probably want to get the 3 2" non ferrous deburring bits(SUM-900230). Then to finish it off you'll need some sanding rolls and something to polish the chambers and exhaust bowls/runners with- I think this kit should be enough for you to finish a set of heads SAI-260012.
What will you be using to do the work? Do you have a compressed air source? I used an air powered die grinder for mine. You could also use an electric powered die grinder but they are a little harder to find. That and most don't have a way to vary the speed of the tool. Some people rig up a dimmer switch so they can change the speed though.
Good luck.
