porting
Old Apr 18, 2010 | 09:34 PM
bayboii925's Avatar
porting
Can someone please share some knowledge on porting. i want a 52 mm tb
Old Apr 18, 2010 | 10:39 PM
henryz28's Avatar
No need to port the intake for a 52mm tb.
Old Apr 18, 2010 | 11:27 PM
95Blackhawk's Avatar
do you mean head or intake porting?
Old Apr 19, 2010 | 06:26 PM
STRYKER's Avatar
I think the OP is referring to porting out the TB from stock to 52 MM ....
Old Apr 19, 2010 | 06:54 PM
Or he wants to know if he needs to open up the throttle body bores in the intake manfold, and as indicated in the first response - no. The throttle bores in the stock intake manifold are already 52mm.
Old Apr 19, 2010 | 10:32 PM
henryz28's Avatar
either way a 52mm tb is not worth much, a cold air kit will be better. Leave the tb and maf stock, change out the elbow and install a cold air kit.
Old Apr 20, 2010 | 05:18 AM
Seems he's not reading the responses, or listening to suggestions about adding a signature....?????????????
https://www.camaroz28.com/forums/sho...d.php?t=747818
https://www.camaroz28.com/forums/sho...d.php?t=748327
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
