Ported heads need work?
Old Sep 1, 2006 | 06:04 PM
SuperbeaSSt's Avatar
i bought these from another memeber, they look to be ported and polished but maybe not professionally. Do they look like they are still good? And if so do they need work still?
Old Sep 1, 2006 | 06:11 PM
wrd1972's Avatar
Re: Ported heads need work?
Looks a bit rough and definitely NOT professional. Did you buy them with this understanding?
If not i would be fired up.
Old Sep 1, 2006 | 08:22 PM
grammerman's Avatar
I've just ported a set of LT1 and had them flow benched. Some of the standard, very basic and easy mods that really picked up my heads look like they've been done OK . Can only tell much from pictures.
To be clear, I'm no expert. I have actually used a flow bech a little and ported numerous sets of heads with what I'd call good performance. From the experience I've had with my most recent set (LT1 heads that were flow tested before and after the porting)_I think you should take a look at the short side radius ( where the intake port floor turns down to meet the valve seat .) If they didn't mess with this very much you'll probably have a nice improvement over stock. Probably not a 280cfm race head but a nice improvement in power across a wide RPM range.
If the short side was totally butchered the head may be hardly any better off than a stocker. could even be worse overall. If someone in your area flow tests them I'd recommend spending a few dollars and getting a couple pairs of ports tested. Then you'd have a much better idea about how they might work and what they might need to fix any weak areas.
Good luck Michael.
Old Sep 1, 2006 | 08:44 PM
snakeatinZ's Avatar
What did you pay for those? Did you ask to see some pics before the purchase?
The best advice I , personally can give you is get them to a pro. and see if they can clean them up for you. It would more than likly cost somewhere around 200 to 400 more dollars. But it would be $ well spent.
Steve
Old Sep 1, 2006 | 08:49 PM
well they came with a bunch of other stuff I bought, no I didn't ask for pics. They seem to have changed hands a few times, so I'm not sure that the person I bought them from knew any better. That aside the name ellis is on the sides of them. I don't know if this is a person or some kind of acronym. But yeah I'm kind pissed but I got a deal for the other parts that came with the heads.
Old Sep 1, 2006 | 10:59 PM
I'm gonna send them the AI for emergency surgery! wish me luck.
Old Sep 2, 2006 | 08:26 AM
marshall93z's Avatar
Intake ports look kinda funny.
Old Sep 2, 2006 | 01:02 PM
MeanGreen97Z's Avatar
Porting companies put people's last names on the heads to keep them seperated so they know who they belong to. I'd have them flowed to see what they do first.
Old Sep 2, 2006 | 01:28 PM
96capricemgr's Avatar
I know on LS1 Tech there is a guy names Ellis think he has run more than a few combos might ask him if they could be one of his long gone setups?????
Old Sep 2, 2006 | 06:33 PM
sam pace's Avatar
Flow bench them first before spending huge $$$ on extra porting or sending out. make sure they do all 8 for consistancy reasons and have also have your chamber size checked too.
Old Sep 2, 2006 | 06:48 PM
Phil at AI is a detail junky he will take good care of you.
Old Sep 2, 2006 | 09:09 PM
engineermike's Avatar
I think they look pretty good! They did a really good job around the valve guides especially, and blending in the valve job. It's hard to tell how high the tops have been raised, what the short-side looks like, and how thin the pushrod pinch point is, though.
Flow them before spending any money.
Mike
Old Sep 2, 2006 | 09:36 PM
I don't know where to get them flowed around here....If you know anywhere around between LA and Riverside let me know.
Old Sep 2, 2006 | 11:33 PM
1racerdude's Avatar
There are several places there. Call Accufab and see if they can recommend any place close to ya. They are in Onterio. Ask for John or George.
Worked on this one a bunch when I lived out there.First 4.6 in the 8's.
Accufab, Inc.
1516 East Francis St.
Ontario, CA 91761
Tel: 909-930-1751
Old Sep 5, 2006 | 06:43 PM
$40 a head? one intake and one exhaust sound right?
