ported heads with hotcam, bigger injectors?
Old Mar 11, 2006 | 11:47 AM
luckyou03's Avatar
I'm getting the LE1 with a hotcam. Do I need 30lb injectors?
Old Mar 11, 2006 | 09:55 PM
Fastbird93's Avatar
Re: ported heads with hotcam, bigger injectors?
Shouldn't. I'm running ported heads on a hotcam and am using a set of 24# SVO injectors (I know, I know, they're flowing a bit more than stock) and have plenty of room to spare.
Old Mar 11, 2006 | 10:50 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Ported heads with hotcam here, stock 24 pounders still going strong. Numbers in sig. By my calculations I am at like 96-98% duty cycle though. I am going to do 30# SVO's when i do the GM847 swap.
Old Mar 11, 2006 | 11:51 PM
Why wouldn't you follow Lloyd's advice and go for a set of 30's?
Old Mar 12, 2006 | 06:46 AM
cehan's Avatar
When I was using the Hot Cam with unported heads, my inj duty cycle at WOT was around 90%. So, I would say yes, why take a chance?
Old Mar 12, 2006 | 07:27 AM
MeanGreen97Z's Avatar
I also ran the HOT cam on stock heads with the stock injectors and got away with it for quite a while. For ported heads and supporting mods.... i'd definately go with 30lb SVOs! You're tuner will like you more if you do.
Old Mar 12, 2006 | 07:33 AM
SS RRR's Avatar
From what I've read and seen it seems the rule of thumb is larger injectors are needed if planning to hit over 400rwhp.
Old Mar 12, 2006 | 08:34 AM
FastZinTennessee's Avatar
I had the HOTcam and a set of homeported heads, my duty cycle was around 93%. I'm sure Lloyds heads flow better than the ones I had, so I would recommend getting the 30 lb injectors.
Old Mar 12, 2006 | 12:24 PM
luckyou03's Avatar
Money! After I pay for the porting I will need a week to recover so I was going to run stock injectors for a week. Just seeing if it was possible.
Old Mar 12, 2006 | 12:28 PM
Including ALL the info in your original post might have made is easier for people to help you.
Sure, you can run the stock injectors for a week. They will probably not max out on that combo, but obviously you don't want to run them long term and push them close to 100% DC on a regular basis.
Old Mar 12, 2006 | 12:29 PM
It's possible.... I wouldn't go WOT too much for fear of running it too lean or putting one of those injectors past the point of no return and you lose a cylinder.
Old Apr 3, 2007 | 04:03 PM
maybe2fast's Avatar
bringing this post back from the dead. I am worried now about the hotcam and ported heads with 1.6rrs
Old Apr 3, 2007 | 04:14 PM
Denny McLain's Avatar
Most likely on or just below the edge where you would need larger injectors but Lloyd has to play it safe if you were to have issues. He's trying to help ya avoid potential headaches. In other words.....probably a good idea and can't hurt, except for a little extra money.
Shoot, if money is an issue, I have two sets of 30 lb SVO sitting on my wall that I can cut ya a decent deal on. That, and about half an engine just in case I need something. A little extra money to save me a little grief.
Old Apr 3, 2007 | 05:52 PM
maybe2fast's Avatar
what do you want for a set of 30 lb
Old Apr 3, 2007 | 09:07 PM
zx1216's Avatar
yeah how much? lol
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
