ported heads and fuel question
Old Jan 9, 2004 | 01:44 PM
  #16
FireAm94's Avatar
Yes I would replace the injectors. It's not a great idea to run high fuel pressure on stock injectors due to the injector style...which is much worse than the SVO pintle style. The stock injectors have a tendancy to lock up under high fuel pressure....which definately is not something you would want....especially if you're trying to PREVENT a lean condition. If you get SVO injectors they are rate at a lower fuel pressure and at stock LT1 fuel pressure they are more like 32lb....so what he said about running at a higher pressure I guess kinda is right...just not very smart to do hehe.
Joe
Old Jan 9, 2004 | 03:53 PM
  #17
cef97ws6's Avatar
Originally posted by Quick96Z
With 85,000 miles on the stock injectors, do you think it would be a wise decision to just simply upgrade the injectors anways, even though i could get away with the stock injectors on increased fuel pressure??
Basically, i want to protect my investment, and not have to worry about melting a piston if i take her up tp 6400 RPM.
I really appreciate all the information though, i thought i knew alot about these motors, but you have humbled me
thanks
trav
If you are not worried about cost then absolutely it would be better to buy new injectors. I just wanted to let you know you don't have to buy injectors if you don't want to. I have run my car with the higher fuel pressure settings for over a year now with no problems but I don't have your mileage. Anyway good luck with your project and I hope it runs great for you.
P.S. FireAm94 how do you like your Strange rear? I am trying to decide on a new one and am undecided as to the Strange or Moser. I am leaning toward the strange unit though.
Old Jan 9, 2004 | 04:48 PM
  #18
FireAm94's Avatar
I love it! The rear even came filled with fluid! hehe The only thing you'll have to do is swap your brakes over and change the ujoint in ur driveshaft. I'd tell you it's strong as hell but I haven't driven it over 1k miles yet (supercharger + stock shortblock = bye bye ringland). Now it's 383 with Musser heads and the bottle.
Joe
Old Jan 9, 2004 | 10:41 PM
  #19
cef97ws6's Avatar
Joe
Sounds good! Sorry about your engine loss but the new one sounds potent Good luck and thanks for the info!
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
