Popping from the muffler
Old Feb 23, 2004 | 08:34 PM
jdizzell's Avatar
When I let off the throttle without shifting out of gear and I’m in the 3000-4000 rpm range, I always get a few loud pops coming from the exhaust when the car is slowing down. It will happen in any gear that I’m in. When shift into neutral and letting the car coast I don’t get that popping sound. Just want to know what could cause this? I was thinking it was backfiring.
Old Feb 23, 2004 | 09:08 PM
Brundle's Avatar
Backfire for sure. Seveal things can cause it. When i was getting it my car i changed the AIR check valves. I dont' get it now anymore.
Old Feb 25, 2004 | 12:28 PM
jdizzell's Avatar
Could bad plugs cause backfire?
Old Feb 25, 2004 | 12:31 PM
Robs97Z28's Avatar
If it was the plugs you would have an engine miss. You could also have an exhaust leak somewhere in the system and it is sucking in cold air causing the popping.
Old Feb 25, 2004 | 12:34 PM
Brundle's Avatar
yep, i believe so.
changing the plugs can't hurt n e ways, good way to tune up your engine
Old Feb 25, 2004 | 12:38 PM
Brundle's Avatar
wait, my bad, rob is right. bad plugs is misfire, not backfire.
Old Feb 25, 2004 | 12:40 PM
airborneluva's Avatar
Does it still do it after the car is warmed up? Mine has the popping when the engine is cold ...so do many people I believe, its normal when cold.
Old Feb 26, 2004 | 10:28 PM
jdizzell's Avatar
It will happen when it is warm.
Old Feb 26, 2004 | 10:31 PM
97WS6SCharged's Avatar
My car would do that when it was running rich. Since I've been playing with the programming (and fixed the fuel pressure regulator), it hasn't done it. Just a nice smooth deceleration note.
G-BODYT56
Jan 14, 2022 11:14 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 22, 2015 02:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
