No front sway bar?
Old Feb 25, 2004 | 08:08 PM
Cmr0z28's Avatar
No front sway bar?
Going to the track Friday night, and I'm thinking of taking off the front sway bar. Should I take it off or just disconnect it? What's it like driving with a disconnected/removed front sway bar?
-Matt
Old Feb 25, 2004 | 08:09 PM
FormulaLT1Power's Avatar
Mine is off...and I haven't really noticed much of a difference to tell ya the truth.......
Old Feb 25, 2004 | 11:18 PM
Cmr0z28's Avatar
Thanks....anyone else?
Old Feb 25, 2004 | 11:29 PM
johnny o's Avatar
You might aswell just take it right off because you are probably going to bust the endlinks anyway. So order some aftermarket ones with poly bushings incase you want to put it back on right away. Taking it right off is only a few more bolts anyway and some weight off the front end and for drag racing that can't hurt. Most people say they don't notice a different except in really hard corners and it makes the car more unpredicatable as to when the back end is going to kick out around a corner. Just my 2 cents.
Old Feb 26, 2004 | 12:05 AM
RED95LT1Z28's Avatar
I wouldn't just disconnect it i would rip it all out. I heard it helps out in the quarter and you really don't notice it from what i heard. Instead of taking a corner at 50 u hafta take it at 30...i'm ripping mine out soon as i get my car back.
Old Feb 26, 2004 | 10:21 PM
revtime's Avatar
Mines been gone for 6 months now, not much difference really ........I usually run on skinnies and DRs though so I don,t take turns too fast to begin with.
Its not a shocking difference if thats what your asking.
Old Feb 26, 2004 | 10:27 PM
Cmr0z28's Avatar
Thanks guys......
I already have aftermarket polyurethane bushings and endlinks on the swaybar.
Old Feb 26, 2004 | 10:38 PM
badblackta's Avatar
I think it does help you to get a better weight transfer when you leave the line at the drag strip. I yanked mine and the front end feels like it wants to lift, now I must get the power to make it lift
Old Feb 26, 2004 | 10:41 PM
OBE1 95Z28's Avatar
If you're a "straight line" guy, you won't miss the front sway bar, but if you're into carving corners, it's going to handle like a pig. Even with the sway bars in place, the stock suspension is just OK for corners. A set of better springs, shocks and a 35mm front sway bar really make the car handle great. It all depends on what you're into. I've got my car setup as a "cross trainer"; I've run 11.68 in the quarter mile and can carve some pretty mean turns.
96SilverRam
Nov 20, 2016 11:19 AM
Alien
Jun 27, 2015 01:13 PM
96SilverRam
May 5, 2015 09:56 PM
BLK1997Z28
May 1, 2015 12:23 PM
8T8IROC
Mar 26, 2015 09:02 PM
