popping at high rpms
Old Sep 12, 2006 | 04:45 AM
speedy1546428's Avatar
Question popping at high rpms
I have a 95 z28 and i noticed saturday night when i was racing a mustang it came off the line ok and when i started to reach around 4500 rpms it started popping backed off and it was fine . I almost lost but didnt , checked my plugs and wires they look fine and checked fuel pressure it is good also any ideas ??
Old Sep 12, 2006 | 07:45 AM
jeff1586's Avatar
Re: popping at high rpms
It could be the opti. I know thats how mine was until after i replaced it.
Old Sep 13, 2006 | 04:24 AM
my opti is new just replaced it about a month ago cause the original one crapped out on me .when it went it was backfiring really bad . the motor has about 5,000 miles on it . thank you for any ideas
Old Sep 13, 2006 | 04:28 AM
my opti is new just replaced it about a month ago cause mine went out it was backfiring really bad. thank you for any input
Old Sep 13, 2006 | 06:55 AM
94_Z28_guy's Avatar
Mine was a bad coil wire. Might want to check the coil too.
Old Sep 14, 2006 | 04:18 AM
Smile Re: popping at high rpms
its a new coil but im gonna check the wire . thanks for the input ,hope it works for me too .ill keep you posted
Old Sep 14, 2006 | 09:11 AM
Bobsep84's Avatar
Yes, check coil wire. I had your exact same problem. I went to change the optispark and notice that the coil wire was destroyed and all rusted inside the boot. Changed Opti and coil wire and problem went away. I can almost bet my old opti was fine and it was just that stupid wire
Z28Freak86
Apr 30, 2024 05:37 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
