popped a code 16
Old Jan 16, 2010 | 03:41 PM
teamstream's Avatar
popped a code 16
Still workin on my 94 Z28 Camaro ...the car will run fine for approx 10-15 mins and just die. It wont start back up for at least 10 mins or so. I did get a Code 16 (low Resolution pulse) (Ignition is not detecting the low resolution) is this trying to tell me my opti may be bad after all?
Old Jan 16, 2010 | 03:46 PM
RamAir95TA's Avatar
Absolutely.
Old Jan 16, 2010 | 05:24 PM
teamstream's Avatar
so why would it run fine then just die? is the opti gettin to warm and messing up?
Old Jan 16, 2010 | 05:53 PM
RamAir95TA's Avatar
Opti's aren't an on-off switch. They can do all kinds of funny things when they are on their way out, many of which don't set a code. The code 16 means that the PCM is detecting 720 high resolution pulses before it detects one low resolution pulse. Without the low resolution pulse, the engine will not start (PCM shuts down the fuel pump/injectors).
Old Jan 21, 2010 | 01:35 PM
canuck94z28's Avatar
The code 36 is also frustrating.This causes a epic bog.I had to replace the factory opti(symptons were there for many yrs.)
Chet1185
Apr 26, 2015 04:07 AM
Gtpguy
Jan 26, 2015 04:50 PM
nophix
Nov 30, 2014 10:26 PM
Hannibal
Sep 6, 2002 05:07 AM
91Bird305
Aug 5, 2002 01:39 PM
