Poor running 93 LT1 - cyls 6 & 8 sooty plugs
Old Nov 28, 2008 | 02:03 PM
Roger Mabry's Avatar
I have a new project, '93 LT1/700R installed in a '72 Jaguar XJ. It runs, but poorly. Cylinders 6 & 8 have sooty black plugs, not oil. The plugs and spark plug wires are new and test out OK.
Headers on the car make it almost impossible to check compression. Any ideas of where to start?
GM manual is on the way but I am looking for ideas in advance. Have no check engine light yet, so pulling any codes has to come later.
Old Nov 28, 2008 | 04:37 PM
Running rich on one bank of the engine is usually the result of misfires on that bank, exhaust leaks before the O2 sensor on that bank, or faulty O2 sensor or wiring.
Old Nov 28, 2008 | 07:34 PM
Wild1's Avatar
Agreed. You may have a header / manifold leak. Do you hear any noise "popping" like a header gasket?
Try a seafoam clean and see where the leaks are.
Old Nov 28, 2008 | 07:52 PM
Header is leaking, but on drivers side
There is a header leaker at the top of the collector on the driver side. Bad welds and the PO had them recoated with the leak!
Can the leak on the opposite side cause this problem?
Old Nov 29, 2008 | 07:27 PM
bubba4's Avatar
I just cured a very similar problem with my 95 Z28. After new opti, wires, plugs, and resealed intake, My code scanner still showed the right bank go rich after close loop. I pulled headers and sure enough the gaskets were bad. I applied ultra copper to the new gaskets and cured my problem.
Old Nov 30, 2008 | 10:54 AM
Leaking headers are coming off today
The drivers side headers will come off today for rewelding and recoating. I also found the near new Powermaster alternator is not putting out any voltage. After charging the Optima overnight, the car ran and started better.
Hopefully the GM manual will come this week and I can get actually started.
cmdeshon
Dec 27, 2014 10:06 AM
Rich_z28
Aug 27, 2002 12:20 AM
JAFO1994
Aug 22, 2002 06:09 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
