View Poll Results: How did your Pacesetter fittings hook up?
AIR and EGR threaded rite up, no problem.
41.67%
AIR fine, EGR WILL NOT thread up.
8.33%
AIR wont hook up, but EGR threads rite in.
8.33%
AIR and EGR fittings both sucked, didnt work.
41.67%
Voters: 12. You may not vote on this poll
POLL ~ Pacesetter Long Tubes ...
Old Feb 1, 2005 | 05:45 PM
  #16
slimdawson's Avatar
Re: POLL ~ Pacesetter Long Tubes ...
You have to move your cats to make them work. Moving cats is a no no for emissions.
Old Feb 1, 2005 | 06:10 PM
  #17
Heatmaker's Avatar
Advanced Member
Originally Posted by camarolover20
Why isnt is legal with Long tubes?
Back in the old days the "Tofu eaters or "Tree Huggers" as they called them than got together with some legistlation and created a thing called emissions... of course these emissions were great for the Tree Huggers... as thier 20hp VolksWagon Love Buses barly made enough power to cause polution, but to all of us car enthusiest it ment the bar was raised higher... years later "Tree Hugger" laws got worse and emissions more ****... in some states... "Tree Hugers" do visual inspections of vehicles... The **** codes go by various problems... but the #1 **** code from state to state is that the original Cat location is altered... or removed...there for it's illegal.
Go figure...
Old Feb 1, 2005 | 06:17 PM
  #18
fesgali's Avatar
I've got some Pacesetter LTs with emission hook ups in the garage ready to put on the car but i'm tempted to sell these and get some without the emissions fittings. I live in MD and i gotta do the smog test so i'm 50-50 right now.
Old Feb 1, 2005 | 06:19 PM
  #19
Heatmaker's Avatar
Advanced Member
I thought Smog test were good unless you don't have cats in MD??? do they have a visual there.... very curious.
Old Feb 1, 2005 | 06:35 PM
  #20
fesgali's Avatar
Even when i rolled up with AS&M, cats, and flowmaster they did a under car visual test. I failed the test 4 times and ended up getting "help" from the worker to pass.
In MD you gotta have cats.
Old Feb 2, 2005 | 12:31 AM
  #21
camarolover20's Avatar
I also live in maryland i m about to find out if it will pass
Old Feb 2, 2005 | 01:19 AM
  #22
TigerWoodsJr's Avatar
I got the race setup...but I did have a problem with the 2nd bolt from the front on the drivers side not being able to fit in past the primary...
Old Feb 2, 2005 | 05:33 AM
  #23
95sr71's Avatar
I live in Maryland also and have done alot of research on emissions. It appears they do not do visual inspection unless you are applying for a waiver after spending more than $450 to fix you emmisions failures. I have also found out that if your car has been lowered to much they will give you a emissions waiver. Has any body recieved a waiver for an f body due to bein lowered? If so how low was the car. The few examples of cars getting waivers for being to low that i have seen have been ricers and they were REAL low.
Jason Robb
Old Feb 2, 2005 | 12:34 PM
  #24
stik6shift93's Avatar
Back when i had my ground controls I had my car lowered about 2.5 inch in the front and 2 in the rear and that didn't stop them. Out here the roller are almost flush with the ground so it doesn't matter, i'd imagine if they had one something like a dyno it might present a problem.
Old Feb 2, 2005 | 12:51 PM
  #25
fesgali's Avatar
Jason Robb
I've got a neighbor that has a mustang that got the wavier because the car was low. I think sportlines make it low enough, thats what i plan to go with anyway.
Old Feb 2, 2005 | 12:52 PM
  #26
fesgali's Avatar
Keep me posted on what happens, what kinda ypipe, cat, and catback are u using?
Old Feb 2, 2005 | 03:12 PM
  #27
DiabloGT's Avatar
http://www.vehicletest.state.ma.us/autotestproc.html
on this site for MA it shows that they do a vidual is that a visual on safety or on cats? how would they notcie if you moved your cat like a little bit?
Old Feb 2, 2005 | 04:13 PM
  #28
95sr71's Avatar
I currently have the motor out and rebuilding as a 383. I am trying to decide how big of a cam and what type of headers to use based on emissions. If I knew I could lower it enough to get a waiver I will use a big came and true duels off of LT's. If not I think i will go with lt's a custom catted Y and a xe 224/230 cam.
Jason Robb
Old Feb 2, 2005 | 05:02 PM
  #29
I got the ypipe with the pacesetters and then i m runing a aftermarket 3 inch cat then i m runing a prebent 3 inch pipe from the cat to the axle to a flowmaster 40 series and if that is to loud i will do the 50's
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
