PO1406 trouble code
Old Aug 24, 2005 | 12:03 AM
roadtrip120's Avatar
PO1406 trouble code
I searched and all i found was 1406 fel pro header gaskets
What is the trouble code PO1406?? Any idea what it means?
Old Aug 24, 2005 | 07:08 AM
moparman's Avatar
Re: PO1406 trouble code
I'm confused. Is the code on the '94? That's an OBDII code, but a '94 is OBDI, unless you changed to OBDII. However, the code is for an EGR problem. The two most common causes are:
1. Clogged, sticking or binding EGR valve pintle or seat
2. Backed out terminals, damaged connectors or wiring
Old Aug 24, 2005 | 08:19 AM
sorry , its on my brothers car 97 firebird ODBII
thanks brady
Old Aug 24, 2005 | 08:30 AM
I have a list of DTCs for the LT1 on my website and that is not one of them listed.
You are probably going to say it is a V6 (if so, should have posted in the V6 forum). P1406 is an EGR valve pintle position code. The V6 uses an electronic EGR valve. The valve may be clogged, wiring or connector broken or valve bad.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
