plugs and wires suggestion
Old May 7, 2005 | 03:34 PM
LUDA0840's Avatar
OK I think my car is running on 7 cyl. Im assuming one of the plugs is burnt. What plugs and wires do you all recommend? Right now it has those bosch 2 platnium. Just had a tune up about 2 months ago.
Car seems to lose power.
Old May 7, 2005 | 03:39 PM
kicksZ28's Avatar
Re: plugs and wires suggestion
I have a 95 Z-28 and i went with the AC DELCO double platinum with Accel 9000 plug wires. Car runs great w/92,000 miles.
Old May 7, 2005 | 03:42 PM
LUDA0840's Avatar
and where can i get this stuff??
Old May 7, 2005 | 04:34 PM
ayalam's Avatar
ngk tr55 spark plugs i have them and they run better than stock imo, plus everyone recommends them and their cheaper. napa has them. for like $2.50 each.delco's cost too much and platinums not very good for the nos. wires no idea. But i see that your gonna get headers so either go to thunderracing.com get the ovet the valve cover kit for $100 u will have to cut and but on the boots yourself not very fun, or i think elitesparkplugs have the otvc made already.
Old May 7, 2005 | 05:57 PM
kicksZ28's Avatar
I know the Delco plugs are expensive but I read alot of the posts here and many suggested staying with the original type. The car is new to me so I have no info on other type plugs. Mine were bought at Autozone. For the wires, I bought them from Summit. The wires had good reviews and tolerate heat very well. I also changed both myself and saved several hundred dollars, but took a little time.
Old May 7, 2005 | 08:10 PM
BLinindoll's Avatar
I will always go with OEM plugs even if they ARE $6.50 each. Sitck with the AC Delco's. As for wires, I went with the MSD 8.5mm super conductor's. They're nice, but you will need to get new wire clamper gripper holder thingers, if you know what I mean, cause the stock ones will be too small for the thicker wire.
Old May 7, 2005 | 09:36 PM
LUDA0840's Avatar
how about the ngk 3403 plugs? There on sale from 6.19 at 3.37. ???
Old May 7, 2005 | 11:07 PM
Lt1t56's Avatar
Just replaced my plugs today and installed the NGK TR55's since a lot of people on this board like them and noticed my car idles better now. I bought them at Oreilleys for $1.49 each.
Old May 7, 2005 | 11:08 PM
LUDA0840's Avatar
wat wires do you have?
Old May 7, 2005 | 11:11 PM
Lt1t56's Avatar
Still stock wires at 113,000 miles
Old May 8, 2005 | 12:41 AM
fredmr39's Avatar
IMO, it's a good habit to get into changing plugs every year. Especially if you ahve headers (since it's easier). So go with the cheaper, TR55s.
PCLZ28
Dec 24, 2015 05:19 PM
eazyZ
Mar 1, 2015 07:12 AM
mritter1965
Feb 9, 2015 07:01 PM
IRABuss
Sep 7, 2011 09:08 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
