Plugs n' Wires: How much time?
Old 05-29-2010, 08:54 PM
FastandBlue's Avatar
I have finals coming up this next week. Bah..... How long will it take to change out the plugs and wires? I'll be running MSD SC 8.5mm and NGK TR55s, prolly the Iridium despite their excessive cost!!!
FastandBlue is offline
Old 05-30-2010, 12:03 AM
Fatdog2's Avatar
First timer, all day and more.I'm not kidding here.Most frustration with the plug wires putting them into the looms.And don't over tighten the plugs in the aluminum heads(always do this when the engine cold.My02.
Fatdog2 is offline
Old 05-30-2010, 12:39 AM
How about time-wise without putting them in the looms? Also, am I going to have to take any components off the engine to get these plugs in? I don't know a whole lot about the LT1 setup in particular, so I'm bracing for the worst.
Old 05-30-2010, 12:56 AM
Fatdog2's Avatar
Just as long as they don't touch anything(metal),They won't short out.Do you have all the proper tools recommended by this board?
Fatdog2 is offline
Old 05-30-2010, 01:02 AM
6SpdLT1Z's Avatar
First time with manifolds? ~6-10 hours IMO. I can't help you with what you'll need to take off as my plugs/wires were done shortly before I bought the car and I replaced the plugs during a header swap.
6SpdLT1Z is offline
Old 05-30-2010, 03:07 AM
Yeah, first time on this engine, at least. I have all the tools necessary, I believe. I have a fairly extensive set of tools for engine work, so here's hoping. Was there anything special or out of the ordinary I need from this particular plug and wire change?
I plan on leaving the manifolds on, but does anyone else know if I need to take anything else off, or will I be able to get to it all without having to remove stuff? This is my primary concern above all else right now. Thanks!
Old 05-30-2010, 06:24 AM
Antigone's Avatar
Alternator and power steering pump came off of mine. #2 plug access and the wire routing made it impossible for me to do unless they came off. Start to finish for me was around 6 hours. My situation made worse with the headers.
Antigone is offline
Old 05-30-2010, 08:26 AM
CstIrnFst's Avatar
I've never done both at the same time, but together it would take hours. I didn't have to take anything off to remove or replace anything. Luckily for me my skinny arms allowed me access to everything.
It's a pain one way or another, start early in the day and just take your time.
CstIrnFst is offline
Old 05-30-2010, 12:04 PM
Alright, good to know. I love these engines, but I'm just saying that whoever designed the frickin things was a retard.... :-/
Old 05-30-2010, 12:11 PM
Do you have anti-sieze compound?
Injuneer is offline
Old 05-30-2010, 12:35 PM
I'm thinking PB Blast. Are they sometimes really hard to get off?
Old 05-30-2010, 12:51 PM
Its not for taking them out. You put a tiny dab of anti-seize on the plug threads, before you screw the plug into the aluminum head. That way they come out easier the next time.
Injuneer is offline
Old 05-30-2010, 12:54 PM
Okay, gotcha. Yeah I was kinda wondering for a second. Yeah I will make sure to do that, don't worry.
Do you have a suggestion on a brand of anti-seize?
Old 05-30-2010, 01:03 PM
Permatex 133AR in a small tube.
Injuneer is offline
Old 05-30-2010, 01:05 PM
Thanks! I'll pick up some.
Quick Reply: Plugs n' Wires: How much time?
