Which plugs for heads and cam car?
Old Aug 28, 2004 | 03:03 AM
llafro's Avatar
In my search to locate my missing 80 hp, I am going to change the plugs and wires to see if that fixes the problem. What plugs do you think I should be running on a stock bottom end heads and cam car? See sig for the mods. I'm running about 11:8:1 compression. I've never changed the plugs myself since the heads and cam were installed, so that's why I'm asking.
Thanks,
BRAD
Old Aug 28, 2004 | 09:10 AM
NightTrain66's Avatar
Re: Which plugs for heads and cam car?
NGK TR6 is a good plug to start with.
It is a lil cooler than stock and works well with most head/cam set ups from what I have seen. This helps with detonation and will sometimes allow a lil more timing before experiencing KR.
Lloyd Elliott
NightTrain66@msn.com
Old Aug 28, 2004 | 10:36 AM
1badasZ's Avatar
thats the same one i went with but i dont have my valves set yet so i dont know how they do so far
Old Aug 30, 2004 | 02:21 PM
llafro's Avatar
I couldn't get the NGK plugs at three different places, including Performance Automotive Wholesale (PAW) here in So Cal. So I finally went with Autolite 104s, which are one range cooler than the stock 106. We'll see how that works. I just want to vent and say that plug access SUCKS with SLP headers.
Thanks for the help,
BRAD
Old Aug 30, 2004 | 05:16 PM
12SCNDZ's Avatar
Splitfire SF10D...Gapped at .050"
Old Aug 30, 2004 | 05:22 PM
LPE Z convt's Avatar
Autolite 103s They worked better for me than alot of the other brand name plugs..
oldschool
Feb 9, 2016 09:21 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
