Plugged waterpump weep hole
Old Jun 11, 2006 | 08:37 PM
seawolf06's Avatar
Doing my cam swap and just thought I would share some pics of how I plugged the weep hole in the wp housing. I tapped it with a 1/4" x 20 tap and used some thread sealant on the allen head bolt. Hope this gives y'all some ideas beyond welding. More pics on the swap soon!
Old Jun 11, 2006 | 08:40 PM
WeirdRich's Avatar
Re: Plugged waterpump weep hole
why did you do that?
Old Jun 11, 2006 | 08:44 PM
If it is not an electric pump, I would think it better to put a little hose on it to direct any drips away from the opti. You really need it open, because it is an indicator when the pump is wearing out.
Old Jun 11, 2006 | 09:05 PM
seawolf06's Avatar
I'm installing an electric pump. I agree that this is the only reason you should plug this hole. Thanks for your observation shoebox.
Old Jun 13, 2006 | 01:21 AM
WeirdRich's Avatar
if you are installing an electric pump, and you install the freeze plug from the front, then that hole will never contact water. Unless the freeze plug gives out, in which you would then have bigger problems than that tiny hole.
Old Jun 13, 2006 | 01:53 AM
TheZ's Avatar
fgfsdfg
Old Jun 13, 2006 | 06:04 AM
Javier97Z28's Avatar
Moderator
As previously mentioned... freeze plug covers that area and the weep hole is no longer an issue. So.. ya did it for nothing, but neat idea if there was a point
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 7, 2015 03:01 PM
eanhl2004
Apr 4, 2015 12:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
