plug wire question
Old Oct 19, 2003 | 07:35 PM
Mystic97Z's Avatar
plug wire question
i've seen people who have their plug wires ran over their valve covers, are those plug wires easy to put on??
i have jet hot lt's, and i need to replace plugs and wires. where can i get plug wires like that and what all will i need?
Old Oct 19, 2003 | 07:49 PM
Hyperspeed97z28's Avatar
OVC wire kit... www.thunderracing.com under ignition stuff
Old Oct 19, 2003 | 08:18 PM
Mystic97Z's Avatar
thanks. i don't have the extra 100$ for that right now, i just need to get my car running. how hard is it to install plug wires on a car w/ headers???
Old Oct 19, 2003 | 08:32 PM
RamAir95TA's Avatar
If you're asking if it's easy to install plug wires on a car with headers routed in the stock looms, no. It's not overly difficult, but you run the severe risk of burning wires if you do.
An OTVC setup is well worth the $100. I haven't burned a wire since.
Old Oct 19, 2003 | 08:35 PM
Mystic97Z's Avatar
well, i could get that kit later,,,if i got it at another time, could i use the same plug wires,,or would i have to get longer ones???
Old Oct 19, 2003 | 08:38 PM
AsianSensation's Avatar
Another option is side mounting. See pic. You won't have to fool with the wire looms everytime you take the vlave cover off. Again, it's $100 from Thunder Racing.
http://www.97ta.com/lt4/lt510.jpg
http://www.97ta.com/lt4/lt509.jpg
Old Oct 19, 2003 | 09:24 PM
lt1coz's Avatar
OVC Wires
This and the parts from Thuner racing is all you need. (click on it.)
lt1coz
http://ken.lowrance.com/Projects/OVC...OVCInstall.htm
Old Oct 19, 2003 | 10:57 PM
revtime's Avatar
Or just save the 100 bucks and route your wires carefully.
If you want OVC for looks then thats cool spend the dough, if your doing it cause your burning wires then you need to route better.
I have Hooker LTs and careful routing and have not burned a wire in 4k miles, not even close.
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
