Pls tell me what NSA RR to get!
Old Sep 14, 2009 | 03:26 PM
valter's Avatar
I am sorry for beating a dead horse... I did a search, and my head is about to explode
Please somebody tell me what RR (NSA) for stock studs to get. Lightly ported '97 LT1, LT4 springs, stock valvecovers, don't want to change anything else. Looking for some power increase, but mostly for reliability. Thank you for your patience!
Old Sep 14, 2009 | 08:57 PM
RamAir95TA's Avatar
Installing NSA rockers requires removal of the rocker studs to install the guideplates, so there's no reason to reuse the stock studs. Upgrade to a good 7/16" stud, especially if reliability is a priority.
Old Sep 15, 2009 | 04:35 AM
user 647483's Avatar
Yes, you don't want studs flexing on you at high RPM.
Comp Pro Magnum rockers are my favorite, although Crane makes a decent set as well.
The idea is to use a quality rocker to keep friction and weight to a minimum.
Old Sep 15, 2009 | 07:57 AM
PoorMan's Avatar
Harland Sharp NSA 3/8 stud. They are "narrow body", full rollers, and they will fit under the valve covers without having to cut them up. No need to get larger studs imo. Your not going to spin the stock block that high anyway. Summit has them. Good price too. I am running the 1.65 but they make a 1.6 also. I also bought ARP 3/8 studs with them since the old ones had to come off anyway to install guideplates.
Old Sep 15, 2009 | 11:36 AM
valter's Avatar
Thanks a lot for the help guys Going to Summit now, I need to get this thing running again!
Old Sep 15, 2009 | 05:22 PM
reamo04's Avatar
comp ultra mags with 7/16" stud
Old Sep 15, 2009 | 05:39 PM
Counted Out's Avatar
Scorpion Roller Rockers make a good product at a good price.
Old Sep 15, 2009 | 06:16 PM
LearJet's Avatar
If your going to replace the studs anyways why would anyone go with 3/8 over 7/16? The studs don't coast any different, neither do the rockers. If it were me I would go with ARP 7/16 studs, GMPP guideplates, 7/16 Comp Promag rockers, and Comp one peice Chromoly pushrods.
Nutty's96
Dec 21, 2015 06:25 AM
karpetcm
Sep 15, 2015 11:07 AM
CoUnTryMuZiCZ28
Parts Wanted
Jan 14, 2004 11:59 AM
TRICK95
Mar 25, 2003 06:24 PM
9SECONDLX
Feb 5, 2003 02:07 PM
