Please take a guess.
Take a guess please.
Just had new short block installed. Getting a little oil leak in the front.
Going to take to mech. for first oil change and checkup (and fix the oil leak).
What's your guess?
Pan Casket?
Timing Chain Gasket?
Or...the oil cooler was deleted. Is there some place it could leak when the cooler is deleted?
Thanks much.
What's your guess?
Pan Casket?
Thanks much.
You didn't mention what year your car/engine was, so I'll take a wild guess....
- Timing cover seal
- Oil pan seal (where it meets the timing cover)
- Crank Position Sensor (OBD2, 1996+)
- Crank Hub seal
- Intake manifold
- Opti or waterpump shaft seals
- Timing cover seal
- Crank Hub seal
- Intake manifold
Thanks guys, I appreciate the input. It doesn't sound like it would be too serious, but I just want to make sure that the mechanic fixes it.
Having spend about 3000 bucks (not including the the short block) for the installation, I believe I should get a leak-free install.
brothaslide
Jan 9, 2016 12:11 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
