Please take a guess.
Old Jul 14, 2003 | 11:25 AM
BUBBA's Avatar
Take a guess please.
Just had new short block installed. Getting a little oil leak in the front.
Going to take to mech. for first oil change and checkup (and fix the oil leak).
What's your guess?
Pan Casket?
Timing Chain Gasket?
Or...the oil cooler was deleted. Is there some place it could leak when the cooler is deleted?
Thanks much.
Old Jul 14, 2003 | 11:50 AM
BitCypher's Avatar
You didn't mention what year your car/engine was, so I'll take a wild guess....
- Timing cover seal
- Oil pan seal (where it meets the timing cover)
- Crank Position Sensor (OBD2, 1996+)
- Crank Hub seal
- Intake manifold
- Opti or waterpump shaft seals
Old Jul 14, 2003 | 12:46 PM
BUBBA's Avatar
97SS.
Old Jul 14, 2003 | 12:51 PM
zhevy-1's Avatar
Timing cover seal, will also be my guess.
Old Jul 14, 2003 | 12:56 PM
Gripenfelter's Avatar
If its on the front I would guess the lip where the oil pan meets the timing chain cover.
Old Jul 14, 2003 | 01:43 PM
quicksilver97ta's Avatar
Beleive it or not my CPS leaked after reinstalling the timing cover. :dunno: I just removed it, cleaned it and the o-ring, no more problems. Might be worth a closer look.
Old Jul 14, 2003 | 01:49 PM
BUBBA's Avatar
Thanks guys, I appreciate the input. It doesn't sound like it would be too serious, but I just want to make sure that the mechanic fixes it.
Having spend about 3000 bucks (not including the the short block) for the installation, I believe I should get a leak-free install.
Midnight_Z
Feb 16, 2016 09:36 PM
brothaslide
Jan 9, 2016 12:11 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Dan Oldham
Aug 29, 2003 06:23 PM
BillWS6Formula
Nov 2, 2002 06:36 PM
