Please Someone Help With My Cooling Fans!!!
Old Nov 11, 2007 | 09:30 PM
  #16
There is testing info on my Tech Page for the temp sensors and wiring.
Old Nov 11, 2007 | 10:32 PM
  #17
Mikes93Formula's Avatar
but does that mean my pcm is ok or could it be bad
Old Nov 11, 2007 | 10:57 PM
  #18
Are you basing your feeling that the engine is about to overheat on the dash coolant temp gauge? Have you verified that the gauge and the sensor its connected to in the driver's side head are correct?
Old Nov 11, 2007 | 11:42 PM
  #19
There is a part of the testing info that requires the use of a scanner to verify what the computer sees. It is an important part of the troubleshooting procedure. Guessing at stuff gets you nowhere.
Old Nov 13, 2007 | 01:38 PM
  #20
Yeah i know.I put a new sensor in so we'll see if that was it in the mean time im gonna test the connector andsee whats up with that.Is there anyone in the boston are with a scan tool i can use?? But what i need to know is if the fans come on when i jump the dlc and they come on when i get a ses does that mean my pcm is ok..or? I at least want to rule out the big one ya know.
Old Nov 13, 2007 | 03:26 PM
  #21
blue89rs's Avatar
It would seem to make sense that if the PCM can turn the fan on, the problem must be with the sensor or wiring from.
Noct
Jul 14, 2015 01:18 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
warmeck
Jun 5, 2015 05:19 PM
Biggiebound
Apr 23, 2015 08:50 AM
