Please recomend some valve springs
Old Jan 26, 2006 | 08:11 PM
  #16
RE AND CHERYL's Avatar
Re: Please recomend some valve springs
Just looked at the Isky springs. Looks like they are good to .550. Unless I got my math wrong, the 227 with 1.6rr will have .552 lift on the exhaust side. Might be a little iffy.
Old Jan 26, 2006 | 08:39 PM
  #17
Stoopalini's Avatar
Just an FYI on the 987 springs I was planning to use. I'm told by comp cams the inner spring will wear against the valve seal, so the valve guides would need machining to make them work. Some on this board report they fit fine, and others have had problems. This makes me think it depends on the factory machine work tolerances?? Not too sure, but I decided to send them back and get the 26918 Beehives instead.
From the Comp Cams Spring Chart
The 918s coil bind at 1.085, although they don't report numbers past 1.15. With an install height of 1.75 (seat pressure = 146lbs/in), and .555 lift, that puts you at 1.195 (open pressure ~318lbs/in)
Thomas.
Old Jan 27, 2006 | 04:19 AM
  #18
Thanx for the info
Old Jan 27, 2006 | 09:18 AM
  #19
truedualws6's Avatar
Originally Posted by RE AND CHERYL
See what ya got and PM or Email me a price. I'm hoping to got with the 227 but might install a CC305 I already have till I have more money. you don't want to sell your "baby" cam do you.
I'm keeping it. I'm one of those baby cam lovers.
I called Isky back when the same thought went through my mind. They said
no problem. If you notice, coil bind on the 235s is at 1.15", which leaves
about .077" on the table if the springs are installed at 1.78". The number I
have been quoted over the years as the minimum safety margin to coil bind
is .050". Thunder Racing also has many customers with the 227, 1.6s,
and Isky 235s with no problems.
I have not yet dug into the spare parts in the garage. I'll send a PM or an
email with the details. Here is my old post from the for sale board:
http://web.camaross.com/forums/showthread.php?t=329165
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
