PLEASE! need help with my beast (in the making)
Old Aug 19, 2010 | 07:10 PM
bayboii925's Avatar
So i just bought a rebuilt motor with 10000 and the parts that he didnt get to were the roller rockers, lifters, pushrods, valve springs and cam. Now i would love to get everybodys feedback on these parts. I really want to go with comp cams 503 cam. Please fill me in on your opinions on these parts. thanks
Old Aug 19, 2010 | 09:02 PM
rskrause's Avatar
Moderator
CC503 is a good cam but I prefer the Lunati "Voodoo" 60121 which offers a bit more "area under the curve" and more optimized valve events.
•Advertised Duration (Int/Exh): 270/278
•Duration @ .050 (Int/Exh): 221/229
•Gross Valve Lift (Int/Exh): .515/.530
•LSA/ICL: 112/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1800-5800
Rich
Old Aug 19, 2010 | 10:35 PM
Rob94hawk's Avatar
Is that 10,000 or 1000? Because that's a lot of coin for just a shortblock with no heads or cam. Was it rebuilt to a 355 or 383?
Old Aug 20, 2010 | 05:00 PM
bayboii925's Avatar
It just a stock rebuild (350). And can you go into more detail about the lunati voodoo. Any info on the other parts?
Old Aug 20, 2010 | 11:50 PM
rskrause's Avatar
Moderator
If you go to Lunati and Comp's sites you can see the specs. You don't need anything special in the way of pushrods - just be sure you get hardened pushrods if you decide to use guidepltes (not necessary if you get "self-aligning" rockers). Stock length will likely be ok, though in theory you should measure in this case you probably won't have to. Either cam will work better with 1.6:1 rockers, just be sure your valve springs can accomodate the lift. A beehive spring works well with most hydraulic roller cams. Look at the cam manufacturers recommendation for springs, but regard it as a starting point, never use LESS spring than they call for. I am a fan of aluminum rockers, don't believe the outmoded idea that they are not suitable for a street motor, they are fine.
Rich
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cheapchevy
Apr 8, 2015 08:48 PM
CARiD
Jan 27, 2015 06:27 AM
